Speed:
Was wondering if you checked the piston wrist pins that connect to the connecting rods. Are they on bearings on plain bushings? The crank bearing is a needle bearing type correct? As long as those bearings rotate freely, those are probably fine. I wonder if the piston wrist pin bushings have some play in them?
Just asking, hope all is fine.
Glenn
