Just came back from the field, changed the Ail servos, It got better but it didn't solve the actual cause, the new Ail servos where twitching not as much like in the beginning but some, very little but still there, it looks like that every time I change or move something it gets better but that doesn't solve the problem ( I'm learning a lot from this )
So this time we are going to the root of the cause ( the ignition box ) like Thai said, it has to be isolated even more than what I have done so far by adding the copper grounding wires to the ignition box, also will be shortening the grounding wires by reattach them on top of the cylinders on one of the fins, that is what I will be doing next, most likely by Friday or Sat.
