Very Cool...
I will definitely give the Tape Idea a go.
Planning on drilling a series of holes, from the inside, then connecting them...
Then using Fine Rasps and Sand Paper to finish the Hatchways in the Upper Hull.
For the Turret I'm planning (at this point) to cut out the turret wall including the Escape Hatch.
Then replace with sheet styrene.
And finally mounting the second Pistol Port.
Haven't decided how I'll tackle the Bustle Box yet.
Other than than that I plan to go simple and use sheet styrene as well...
I may just add on to the existing box...
Thank You for your guidance and ideas.
-gus
