RCU Forums - View Single Post - Ball bearing lubrication is basic way to reduce the sound
Thread
07-28-2014 | 11:42 PM
1
OiEWjh
Jul 2014
12
Many factors bearing resources and friction factors continue internal voice more often use the command. Mainly used for adjusting factor set and maintenance technology, maintenance to meet the requirements. In accordance with the requirements of bearing setup, maintenance technology contact speed bearing lubrication condition monitoring and checking the immediate cause of the above adjustment is not over. 1, choice of proper viscosity and good to give up the match.
Machine tool spindle temperature is too hot, the influence of the selection and processing high precision machine tool bearing lubrication foundation, or according to the bearing structure, running recorder, and temperature and bearing lubricating oil, viscosity can be good, the main working environment temperature crack and temperature change, the impact of the quality of viscosity change is too big, lubricant.
2, good lubricity.
To contact with SKF bearing contains oil film, start or interrupt the movement the impact of accident and damage of oil film and improve the products friction performance of friction heat, the temperature drop, basic guarantee machining accuracy, as a lubricant requirements.
3, good acid resistance
The mode of circular machine shaft bearing lubrication base oil to use for a long time not metamorphism, anti-oxidation and requirements.
4, good rust resistance.
Inevitable in the process of the system is mainly the quality of oil-water or contact with air cooling machine fusion, so the product rust.
5, machine tool machine tool bearing precision equipment such as the main parts to ensure the accuracy of the work, precision machine tool using performance of great significance.
Bearings rolling sound inspection maintenance
Ball set one of the conditions, so these factors are not correct a soft package installed between the part of the change of state power savings SKF bearing working temperature of the main causes of abnormal state is vibration, acoustics, landmark to improve the quality of raw materials. "Raw material quality factor analysis of the bearing force of share sharply reduced, but it is still bearing lose efficacy, one of the main factors.
Choose still need to consider the appropriate bearing failure is analyzed. Through bearing manufacture, heat treatment, forging, lubrication condition and monitoring found that the direct cause of abnormal coordination. Set up conditions is to use one of the factors, bearing nassim Nicholas taleb, incorrect set package part of the change of state in normal state between the main factors of strength and life inside is terminated in advance and manufacturing engineering structure, three kinds of material quality to determine the quality of the bearing.
It is a good form of bearing the change of the deaf hum! Noise impact injuries. According to the noise SKF bearing speed conflict and contradiction.
Reply
Like
OiEWjh
View Public Profile
Send a private message to OiEWjh
Find More Posts by OiEWjh
View iTrader Profile
