RCU Forums - View Single Post - Can engine be too lean at mid throttle?
Old 07-29-2014 | 10:02 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Cutting out on throttle transition usually indicates a lean low speed setting. If there is a midrange adjustment then it's a piece of cake. If not, then you have to battle with having the proper midrange mixture while not being too rich at idle. The idle speed may need to be a tad higher to help combat this issue as well as a hotter glow plug.
