On the bench for today, cut and fit the canopy frame. I may have to order a new canopy. The one I used for a mold is really beat up. I will clean it to see if it is salvageable. There are some creases from pulling it out off of the frame.
One thing I will try today is to make a sanding plug from spray can foam. Once the frame is glued on there will be lots of sanding and support is necessary. I may try lining the inside with an old t-shirt and plastic wrap then fill it with foam and let it expand and dry.
TB
