RCU Forums - View Single Post - Need help with figuring out how to hinge this arf
Old 07-30-2014 | 07:17 AM
Radical Departure's Avatar
Radical Departure
My Feedback: (13)
Originally Posted by jester_s1
I don't know if a microballoons mix would hold a hinge. The classic way of doing it is to epoxy in a hardwood backer. To get back there, I'd tack CA it onto a dowel rod, check the fit, then put the epoxy on and let it set. You'd have to hold it there fora little while if you use 5 minute epoxy, then break off the dowel rod. It'll probably work best to put the epoxy onto the fuselage and just wipe a thin coat onto your backer piece so that you don't rub it off on the way in.
Have to agree, to get more wood on the backside, tack piece on a dowel any number of ways, apply epoxy and set it in place. Doesn't look that hard to get back there, its a straight shot to it.
