RCU Forums - View Single Post - First flight - GP Extra 40 and Saito 72
Old 04-28-2002 | 02:29 AM
ilikeplanes
Default First flight - GP Extra 40 and Saito 72
Well, this is the plane I selected to get back into the hobby after not flying powered R/C for 10 years. I did get some sailplane stick time around '96 though. After having some trouble with the Saito, fixed with an O.S. 'F' glow plug, I finally got out to the field. Advanced the throttle, corrected rudder, and was flying. It did need some up elevator trim such that the top of the tapered elevator was parallel with the horizontal stab. Landing was quick but solid, no problem. I only put three flights on but I was back into the aerobatics mode immediately. Now all I have to do is work on straightening my maneuvers. :stupid: The "low" control throws are very low. I will be using "high" throws next time. The plastic wheel pants have already started to crack and will get some fiberglass reinforcement. The Saito 72 is just barely enough for continuous vertical flight. I am still having trouble with a rich midrange. Hopefully more break-in will sort it out. The O.S. plug is well worth the horrendous $10 price tag. I can now maintain an exceptionally slow idle.
All in all, I would recommend this plane to anyone past the basic trainer stage.
