RCU Forums - View Single Post - C&H ignitions
Thread: C&H ignitions
Old 07-31-2014 | 09:53 PM
bcchi
Originally Posted by All Day Dan
OOPS! The mechanical advance was available in both colors. Dan.
Right Dan,The Syncro Spark module could in either cas brown or silver.If it has a timing module,should have a Syncro Spark sticker on back of case.Only sure way is to remove the case cover and see if there are two circuit boards .The larger high voltage board and smaller circuit in back of high voltage coil.Don't lose insulater card between case and HV board.
BCCHI
