RCU Forums - View Single Post - Thermocouple issue ?
Old 08-03-2014 | 05:31 AM
philjac94's Avatar
philjac94
It sounds as though the ecu parameters are not quite correct. The RPM should remain during early stages. If this is not set correctly you can bet that other start and run parameters are not correct either.
Go thru start and run menu's taking note of these figures. Send them to my inbox and I can try snd help you out from there.
Will also help to know the size of the turbine.
Phil
