RCU Forums - View Single Post - 2008 the year of the Turbinator
Old 08-04-2014 | 03:05 PM
  #350
Ron Stahl
My Feedback: (12)
Originally Posted by KJ-66
Hi Guys
The stabiliser halves are almost complete and just installed the hinge block on the T/E side. On the plan,there is a 1/4" dia hardwood dowel,which goes into the S1-S3 ribs on each side. Problem is how to glue it in there,with the balsa sheeting on either side on the stab halves? Each tip of the stab is raised by 1 1/2" and the dowel is there to strengthen the joint of the two halves.
Any advice will be appreciated.
Regards
Craig
Dont worry about the dowel. Use a small width of fiberglass on the top and bottom of the stab joint. I built my 125% one with foam cores and that's how I joined them.
