Yasu w1nd6urfa , ego pistevo oti iste kala
So I do not understood your question about the wing,
About the wing ribs, I don't made any bottom tabs, because I made one main longerone, and the longeron will hold the ribs in the correct position and does not need have bottom tabs (legs)
Yes, the aileron and flap hinges will be work of the builder, every modeller uses different types of hinges.
About the landing gears it is early for the " bulgarian model" I made 9mm plate in every wing for the gears. The lending gears I think Robart , Sierra and Shindinmachine will be OK ,
Now I think for SPINER, I wonder that I must to make mold for 5 blade spiber..
http://www.shindinmachine.com/SPITFIRE/SPITFIRE.html
http://robart.com/collections/gear-f...ctric-retracts
http://www.sierragiant.com/prod20.html
