Yeah, most any engine will spike temps when first shut down. The heat is still there, but the cooling airflow is not. You can even notice this phenomenon on car engines. And yes, it will definitely run cooler in the air. If it doesn't, revise your airflow/cooling setup with the cowl on.
AV8TOR
