OS 110 a
Has anyone had experience replacing the case of an OS 110 a? What are the pitfalls of removing sleeve and bearings from the old case and is that reasonable or should new sleeve and piston be used. The engine still has good compression. The case cracked diagonally across the bottom. No crashes or hard contact.
Jerry
