RCU Forums - View Single Post - Ignition question
Old 08-10-2014 | 04:39 PM
stevegauth30's Avatar
stevegauth30
Default Ignition question
Question, are these electronic ignitions generally all the same? The reason I ask is I have a 46CC Brillelli with a CH ignition that I suspect is on it's way out. I have a spare ignition from a DLE 20 that I'd like to try and see if the problem is still there. The problem I'm having it that when I start the engine and keep the idle low, every thing is fine. But as soon as I push the left stick up, all the control surfaces start going nuts. Looks to me like a lot of RF noise. Will the DLE ignition run the Brillelli?
http://youtu.be/Paa0bt-tgL8
