RCU Forums - View Single Post - Ignition question
Old 08-10-2014 | 05:15 PM
BadAzzMaxx
Check your spark plug and make sure it has a register spark plug, There should be a R in the model number.
If you engine has fixed timing the DLE will work if you use a CM6 plug in the engine. The Brillelli has 14mm plug threads so you will have to use a 14mm to 10mm adapter to use the CM6 plug.
Milton
