RCU Forums - View Single Post - Ignition question
Old 08-11-2014 | 01:14 PM
  #31
stevegauth30's Avatar
stevegauth30
Not to say that it can't be, because anything is possible, but everything is brand new. Rx, bat. Switch, IBEC, servo leads, all but the one throttle servo. For now, I have a crap ton of stuff to look at and check. You guys all had good ideas for me to look at and I will check EVERYTHING. Starting with the plug cap. I will try another switch, battery, and reciever if the plug cap doesn't help. I'm sure with the help of all of you, I'll figure it out. At the least, I learned a lot of what causes this stuff and how to avoid it. I also have a brand new digital servo I'll swap out with the old one on the throttle and probably move it inside the cabin. There's plenty of room. Thanks again.
