RCU Forums - View Single Post - Ignition question
Old 08-11-2014 | 06:44 PM
  #34
OliverJacob
My Feedback: (12)
to the op - you can make a simple test to rule out the servo. Disconnect the throttle servo lead from the rx and run the engine with either moving the throttle by hand or a servo tester or separate rx, whatever works for you.
Make sure your radio is on and you'll see if you still get interference. If not - your throttle servo setup is the problem
