RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 08-13-2014 | 04:24 AM
  #1878
rhklenke's Avatar
rhklenke
My Feedback: (24)
Originally Posted by husafreak
I may have to try that crow. I have gotten very used to the way my Hawk lands after so many flights but it does "hang" if the nose is raised too high on landing. That is a good way to describe it. If I have too much AOA it will just level off and decelerate in level flight until a wing drops. I am very careful not to let the nose get too high. 3/8" sure sounds like a lot though! But I may creep up on it.
Yep, that's what we've seen - several times which resulted in damage. The crow seems to eliminate that tendency nicely. Note that 3/8" is the amount up from the aileron position that is even with the flaps when they are up. If your setup is like Dave Wilshere recommended, you're already up 1/8" from that in the normal configuration...
Bob
