I'd pull the carburetor off and soak it in fuel, then make sure the fuel passages are all clear. Old castor oil likes to harden up in those small spaces and can give you fits trying to make the engine run. And I'll second the other recommendations made already to go with a 6v battery and replace everything in the tank. You'll probably need a new glow plug too.
