JC
Started out with the recommended CG. After first couple oflandings move the 2 life 3600MAH from the front below the pilot to behind themain wheels. I still can't hold the nose up long on landing. That is supposedto be way to tell if you are close.
I am not sure of the throws. I do use a lot of expo. I haveabout 55% expo with 80% movement on the ailerons. They are very sensitive. Ihave as much throw on the elevator as movement will allow without touching thefuse. I also use about 40% expo on it.
Let me know how it goes with the Tomahawk.
