RCU Forums - View Single Post - Negative Gs at the top of loops
Old 08-14-2014 | 01:23 AM
HarryC
Originally Posted by MAVROS
Harry C,
Mate if you care to google control reversal at high speed compressible air flow you may understand that it is real.
Yes transonic and supersonic flight is possible nowdays because engineers have proved the phenomenon and designed wing structures acordingly
rgds
Mavros
Ailerons do not reverse their effect, not does any control. Early structures had problems with the wing twisting in the opposite direction to the aileron but it is true at any speed if the wing is not stiff enough, it is not exclusive to supersonic flight. It is a phenomenon of a weak structure, not some magical reversal of the aileron's aerodynamic effect.
Ailerons act the same way .... unless you induce supersonic airflow
What that says is that ailerons, ALL ailerons, reverse their effect when supersonic and that just isn't true.
