Before you try this i suggest you copy your model to memory and experiment with the copy.
Gyro menu settings for your initial flights. This setup features an off position.
photo 1 shows the settings for the off position
photo 2 shows the settings for low gain
photo 3 shows the settings for high gain
for this setup select a switch OTHER than your condition don't worry it is easy to reassign the switch later
