RCU Forums - View Single Post - YGE fire / Programing
Old 08-14-2014 | 08:16 PM
Dave Harmon
Originally Posted by J Lachowski
Dave,
I assume you are using the 100A ESC? What motor are you using? I am running Pletty Advances. May have to get one t play with . Seems reasonably priced too.
Hi Joe....sorry for the late answer...been out flying Snowman's new Biside.
Yep....the OS OCA-1100HV.
I'm using the Plett Advance in the Biside, Nuance and Gaudius and there has not been one moment of problems of any kind.
The small OS programmer is a must have....very small and it stores the ESC settings and allows you to make changes in less than 2 minutes.
I completely programmed Snowmans 1100HV from the factory defaults in just seconds.
The programmer stores the settings as well so you can set up another ESC simply by downloading to the ESC on the flight line....that's what I did late this evening...of course it flew just fine.
I have a Plett EVO in the Gaudius with the 1100HV and it uses the same settings as the Advance.
There is a small instruction sheet that comes with the unit and shows how to set the manual endpoints....no weird language...just the facts....it works.
if you get the OS and need the settings...PM me and I'll get them to you.
Dave
AMA5053
NSRCA 586
