Originally Posted by
dontrinko
So if I understand you correct a 5.5 x 4.5 would lower top speed but have more power at the low end? The props i have seen are cheap so I don't mind buying a few to try. Thanks for the quick response. Don
What you need is less pitch to give you more torque at the bottom end. What does the manufacture suggest? They usually suggest a couple.
