Thanks. The motor stay cool compared to my car motors for a similar time. I need to try it in the water before i try to much more. I'm having trouble getting the props ballanced.
I was using 2 razer blades. I have a balancer on order. I have one prop with only slight vibration. It is an acceptable level for now but still a little vibration. 11,500 rpm is most of the problem. Ther is almost no vibration at 2/3 throttle but at full it is still apparent.
The factor prop was horrible, even at 8400 rpm (stock motor) it had bad vibration. With the new motor ( 11,500 rpm) the wires were braking and the prop was vibrating 1/4".
When you looked at the two motor wires it looked like 4 wires! LOL Not good1 Don
