Originally Posted by
BaldEagel
Don't use the powered glider mode on Futaba radios for a powered airframe use the Airbrake function, it has all the mix's built in.
Mike
+1...Mike is right on the money. Gary, it will take you all of about 3 minutes to set up what you are after without affecting you elevator sensitivity in this menu. The best way to go by far. When you go to test fly it you can adjust your trims in each flight mode if you have separated your trims in flight conditions. When you land after a test flight, make some measurements in each flight mode on the model, zero your trims and replicate the final desired trim positions by making further adjustments in the airbrake menu.
