RE: Inverted engines
It is not a good idea to mount the fuel tank lower than the carb. The opposite problem will occur, you might go lean at less than half a tank. Ideally, the center line of the tank should be on the same line as the center of the carb. In situations such as yours I usually use a fuel pump such as the Perry regulator the Kline regulator.
