Bad plan. Do not remove the throttle stop screw on an Evo 10. There will be nothing left to hold the throttle barrel in! That screw is a huge component in the function of that carb.
Throttle stop to be adjusted per the owners manual. You might want to have another look at that section. Contrary to most directions, the Evo 10 carb adjusting section of the manual is very well written!
