RCU Forums - View Single Post - Interference and 2.4GHZ
Old 08-19-2014 | 11:00 AM
Rodney
I have to dissagree when you say it is impossible for 2.4GHz to be interupted by ignition noise. There is still one way it can happen, if the noise is so intense or heavy that it blanks out all (or most all) of the incomming correct data packets. I have seen this happen only one time but, while highly unlikely, it can happen as I have witnessed it. Up until that time, I also thought it was impossible and did hours of experiment in testing trying to prove it was some other cause without success. Finally, replacing the ignition module removed the problem.
