There's a spring in the bottom of the hole the throttle barrel fits in (that's actually a little stronger than need be). This spring holds the barrel up against the guide pin that also acts as an idle stop. Bottom line, good idea, but not very likely that barrel movement is causing the issue with increasing idle speed.
