Originally Posted by
oh44077
have an easy tiger monster spit 110 inch wings span. or a plane similar to this? would like to know what your cg is. I used the vanessa cg set up . I had no page telling me what it should be. total plane wt. is 40 lbs. 4 lbs. under required max of 44 lbs. required 8 lbs. nose wt. with vannesa set up. using 5.8 first place engine. 26/10 prop. almost ready to maiden. went over my head with this. 80 years behind me should have known better. oh well thanks charlie
I have a Clark Industries 115 inch Spitfire MKIX and the CG was 7 1/2 inches from the leading edge at the fuse...
