I did try the supplied hopper tank, I found the ID of the aluminium tubing was simply too small for a larger turbine, it ended up with cavitation and fuel suction issues resulting in a flameout.
if you use it, I would suggest changing the stopper and tubing for something that will be slightly less restrictive.
for an 80 size turbine it would probably be fine.
