Originally Posted by
Cougar429
Wow! Looking at those head screws would guess that one has been apart a few times.
The wrong tool was used...
"Most people and companies outside of Japan have absolutely no idea what they are. With the similarity in appearance to the Frearson and the Phillips the screws are often damaged in removing and installing with the wrong tools. JIS tends not to camout like Philips. The JIS driver can be used on Phillips quite easily but not reciprocally. "
I've been called a "Feckless Fool" for waiting to obtain the correct screw driver to remove the backplate of my Fox Eagle 60 as the instructions call out the correct tool to use.
This was what I was trying to avoid....
http://www.instructables.com/id/When...rial-Standard/
