Originally Posted by
supertib
So if the bearing is damaged and spinning off center then it needs to be changed......your first post I read as the bearing was good, but leaking... now hearing its rusty and corroded changes things quite alot......
We are arguing about a solved issue now.
Yes, I didnt include that info in the first post that was slightly misleading and confuzing, I apologize.
Either way, I cannot look inside the bearing which is installed onto an engine (crank case), after taking the bearing apart and then looking upclose, I found that out.
