RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 08-25-2014 | 03:53 AM
  #1907
mjunior
Alan,
For the first flight I set the CG at 190mm (only UAT full). All control surface movements were set as per the manual with 30% expo. It took off easily but require a good amount of elevator trim up to keep straight flight at half throttle. After land the elevator trealing edge was around 5mm offset (up) from the initial set up. For the second flight I removed 160gr (around 5,5 ouces??) from the nose. Became better but I didn't measure the right CG position.
Mucio
