I've got the older CC Ice 100's. Will check on data logging on them!
Props... As far as I can tell, not many guys have electrified their VQ Lightnings. I need to go back thru a couple of threads to see what props they used. I'm not sure how 16's will look. They'll physically fit with decent clearance, but I suspect they'll be a bit on the "too large" size.
Have you seen any epowered VQ's? If so, what were they running.. motors and props wise?
EDIT: per eflite, the Ice 100's log Battery Voltage, Currents, Motor RPM, ESC Temperature and more.
