RCU Forums - View Single Post - Binding
Thread: Binding
Old 08-28-2014 | 04:26 AM
G0ldengoose
Originally Posted by Maj_Overdrive
There are different varieties of 2.4ghz. Some have a bind button, some have a bind plug, but usually there is a specific sequence that needs to be followed. We really need to know the manufacturers of the transmitter and reciever you are trying to bind. You could also lookup the manufacturer and likely find a manual for the radio on their website.
With any used rc, especially one with radio problems it's always a good idea to recenter the servos and the linkage. Take the servo horns off the servos and then turn the radio on, centering the trims. Then put the servo horns back on and adjust the trim (or subtrim if equipped) and check the servo throws. I'd also try checking the servos with your other radio to completely rule them out.
Hey,
I have the origininal one that i think may be broken (Etronix Pulse - it isn't listed on the site anymore but very similar to the GFSK).
I wanted to try and test it with the losi stock which i believe to be the Spektrum LSR-3000 or the kyosho stock which i again believe to be the Syncro Kt-200. the receiver is Etronix Pulse Gfsk 3Ch 2.4Ghz Receiver (Et1060).
I've had a look for the manuals for these two but can't really find much (at work at the moment) - i just need to know how to bind them so i can test to see if it is the transmitter thats faulty.
Tom.
