RCU Forums - View Single Post - Binding
Thread: Binding
Old 08-28-2014 | 04:48 AM
Maj_Overdrive's Avatar
Maj_Overdrive
I'm not familiar with that brand at all. I did find a Etronic Pulse GFSK with the same ET1060 model number though. The site didn't have a manual but the pictures showed a reciever that required a bind plug. A Bind plug is just a simple servo plug with a jumper wire in it. You place it in the receiver port that says "Bind", then turn on the transmitter in bind more and turn on the receiver. That's usually the process.
As I said before there's lots of varieties of 2.4ghz and they don't all interact with each other. This is due to the modulation used. Losi/Spektrum uses DSM and DSM2, the Losi "Pro" radio with endpoints is DSM2 I believe. Futaba has FASST and is also using FHSS for a few models. Kyosho uses FHSS in their Syncro radio. There's also FHSS2 out there, GFSK and probably others I'm unaware of. Your GFSK receiver will not work with the FHSS Kyosho or DSM Losi. I'm not even sure if a FHSS Futaba will work with a FHSS Kyosho.
