RCU Forums - View Single Post - Tiger 1 (Early, Middle or Late...)
Old 08-28-2014 | 01:59 PM
Imex-Erik's Avatar
Imex-Erik
Originally Posted by Augustus1967
Prepping one of the Taigen Tiger Hulls to proceed with an Early build.
Picked up a set of Taigen Steel Gearboxes to drive this hull.
One issue I see, the left side looks ok, lining up with Three mounting holes.
The right gearbox seems to align with Two holes only.
Am I right in thinking I will need to Drill and Tap the missing mounting hole in the Base Plate?
Or I guess I could drill a hole in the Gearbox to match the offset Mounting Hole in the Base Plate...
-gus
Yes one of the gearboxes only mounts with two screws on the Tiger 1. If you feel it necessary you can use three, but my brushless tank I just posted did pretty decent with 2 and it had a lot more torque and speed going through it. Nice primer you got going So have you decided to go full early or a mix? I have always liked the mixed builds
