Originally Posted by
ingleburn
Me being the crash test dummy on this project suggested it as a way of fitting a PDB in between the plates.
Ended up being a waste of time as the one I chose didnt give clean enough power to the Vtx
https://www.hobbyking.com/hobbyking/...dProduct=55556
On my next rebuild it will be coming out and Ill use the space to fit the esc,s in. Brians excuse is he cant solder for s h i t and needed 5mm spacers to make some room
My battery fits in between decks so pendulum effect is not there.
Dang! Really? 5A not enough for your VTX?
Oh, I think I see... Unless you're running 4S, you aren't going to have enough voltage to get 12V out of that for your VTX or camera. It's a step-down only; you'll need at least 1-2 volts higher input than your desired output. With 11.1V nominal for 3S, that's 9-10V max out.
As for can't solder... I certainly don't suffer from that.
but I still thought that PDB I linked to above was a good idea. It's black, not purple, BTW.
On a related note; I just received this from Radio Shack:
http://www.radioshack.com/product/in...ctId=15725446#
It's pretty good clone of a Weller WSL base married to a Hakko ceramic 70W iron; at $22.47 on clearance, it's an awesome deal. Good enough that I put my Weller WTCPN away for reserve.
If you can find it at a store near you... they went on clearance for last Christmas, so not many left. My local RS told me I Got the last one in Tejas.
mnem
Shopping list is getting shorter!!!
