RCU Forums - View Single Post - Eagle Aviation One Design Build
Old 08-30-2014, 05:05 AM
  #54
gordon_mcln
Hi Tony - Hope you are doing well...I still have the One Design plans, but would like to use this foam method for a 33% Ulery Laser.
I have two questions...In the opening sequence, were the foam rib blanks glued to the board with poly glue?
I will need to build one of these foam cutting rigs....Did you develop yours on your own, or can you point me to a link that you worked from. Talk to you later.
Gordon
