RCU Forums - View Single Post - Glue joint resistance comparative test.
Old 08-30-2014 | 10:28 AM
olnico's Avatar
olnico
Here is the first test conducted with 5 min Z-poxy.
The hard wood surface is traced with the bracket shape and cleaned.
A diamond point rotary tool is used to imprint the wood.
10 dots are made in the wood with this tool:
The PYCABS servo bracket is saturated with glue:
The hard wood beam is saturated with glue as well:
The servo bracket is maintained in position for 16 hours with a pump clamp:
The servo bracket is then progressively loaded. 5 kgs:
10 kgs:
15 kgs:
20 kgs:
25 kgs ( sorry, the 5 kgs weight is on the other side of the load ):
The glue bond sheared at 25 kgs, a few seconds after I took the picture:
The glue took partly some wood away, and some glue sheared off the bracket:
