RCU Forums - View Single Post - 140 rx trouble
Thread: 140 rx trouble
Old 08-30-2014 | 04:37 PM
cyphur01's Avatar
cyphur01
Originally Posted by essyou35
Also, I just got my P180rx back from jetcat. I asked them to service it and they didn't. I have had sent it two times and hoping they have it fixed now. I'll run it up today but they put an entire 2 minutes of testing on the engine.
I say this NOT to bash jetcat but to inform you, that its entirely possible they barely tested it.
If they knew the problem, why would they run it for a long time? My motor did all the leg work for yours. They put over 6 hours of run time on my 180rx in flight making sure all the adjustments were correct for "the fix." They probably opened your motor, noted the problem, fixed the problem, test ran it and it was good. I now have what amounts to a brand new engine. Accel is astounding and static thrust is incredible. Try it you will see. Also how many hours are on your engine? It wouldn't make sense to service an engine that has a 50hr service interval with very little time on it. Services are not free and they probably wanted to save you money.
