RCU Forums - View Single Post - Glue joint resistance comparative test.
Old 08-30-2014 | 06:25 PM
olnico's Avatar
olnico
Originally Posted by mort78
Great test Oli,
That 5 min epoxy did hold up well, for sure. I agree with Vettster though, you might have issues with the wood giving away first when you use some glues that have more time to penetrate. But I guess these servo mounts will generally be bonded to a servo hatch which would be made of wood, so the test shows what would give up first under pressure! Perhaps you could try with your nice carbon servo covers?
But I guess we'll soon see
I have a run to Dubai coming up on the 9th Oli. I get in at 2055 local time and pretty much stay for 24hrs, if you're around?
Yes, choosing hard wood over aluminium was all about where the glue joint is going to be made. It is fairly rare to bond stuff directly on aluminum in our models.
I can flip the wood grain for sure, or also use a plywood plate. At the end of the day I want to test the joint resistance, not the adherence resistance.
So if I see that wood gives up first in my tests with stronger glues, I will change the holding surface.
