On the bench for today, wing panel lines. The wing is ready for panel lines and the last item I needed to install was the Pitot tube.
I glued in a brass sleeve for the brass Pitot tube to slide back and forth in.
This allows the tube to be pushed in for transportation and for storage.
I piece of silicon tubing around the sleeve holds the tube in place. It then can coil up into the wing when pushed in.
TB
