The new Yokomo DIB Ver.2 PREMIUM in Red or Blue Now at Banzai Hobby!!!
Popular Yokomo DIB Ver.2 is now available as Premium Edition!! Premium edition include Full Aluminium Bulkhead. (Front & Rear Aluminium Bulk Head, Center Aluminium Bulkhead)
DIB ver.2 include Aluminium Type A arm! You can now easily adjust the front alignment.
By using Rigid Aluminium Lower Suspension Arm & Upper Arm Bulk Head, there are more option / adjustment front and back, for Upper / Lower section. Also wheel base and caster angle can be easily set.
There are so many variable option (easily adjusted) for tread, lower arm and damper position, you can set up perfect drift set up with DIB ver.2 suspension system.
Features:
In-Line Layout Chassis
2 belt driven chassis for perfect control
Many alignment can be achieved by Aluminium Front A Arm
Front Midship Motor Layout
Full Counter Drift can be achieved with DIV ver.2 acherman ratio.
Steering Angle 45deg.
SSG Double Deck Chassis & Damper Stay
High precision aluminium motor mount
Low Friction Universal Shaft
Aluminium Oil Shock
Full Ball Bearing
Yokomo DIB Ver.2 PREMIUM Red
Yokomo DIB Ver.2 PREMIUM Blue
Get in quick as these are in HIGH DEMAND !!!
Please Join us on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
