Originally Posted by
SIX GUNS
Bob do you still have the P-47 and the F4U . Don't you have a G62 in the
P-47 ??
Yes I do, but do to health and weather I have not flown the Corsair I a year, and the 47 is ready to go after clipping the corn last fall.
Had the Corsair out but d#$@m air pump bat went south so just able to run it around on the ground a bit.
Becouse these 62's are shakers I recommend soft mounting them, also I have found that making the mount plate out of steel may eliminate the need for nose weight to balance.
Cheers bob T
