Demon Cortex Gyro question
I have the new Cortex gyro I want to install in my Skygate hawk. I am using spectrum failsafe receiver setup and I not sure about the connection. It shows to have a place for 2 satellite antennas. Do you have to use 2 of the satellites that you are using with the current receiver? Or do you add 2 more? Or are they not required? I don’t understand the reason for that conection.
Also what are you guys doing for the nose wheel and rudder with only one channel? I would think you use the rudder and not have it on the nose gear. Not crazy about using a y-harness but I would love to have it on the steering.
Last question is can you still use your dual rates and Expo with this gyro.
Thanks for the help
