RCU Forums - View Single Post - Demon Cortex Gyro question
Old 09-02-2014 | 08:50 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by jws_aces
I have the new Cortex gyro I want to install in my Skygate hawk. I am using spectrum failsafe receiver setup and I not sure about the connection. It shows to have a place for 2 satellite antennas. Do you have to use 2 of the satellites that you are using with the current receiver? Or do you add 2 more? Or are they not required? I don’t understand the reason for that conection.
Also what are you guys doing for the nose wheel and rudder with only one channel? I would think you use the rudder and not have it on the nose gear. Not crazy about using a y-harness but I would love to have it on the steering.
Last question is can you still use your dual rates and Expo with this gyro.
Thanks for the help
The Cortex provides you the option to use 2 Spektrum receivers but they aren't required. I could see them being useful in something like a simple sailplane that only needed 2, Ailerons, 2, elevators and a rudder. If you plugged in 1 or 2 Spectrum remotes in such a setup, no external receiver would be required.
If you're using an external receiver, simply don't add any Spektrum remotes to the Cortex. Just follow the setup guide and, for example, connect your right aileron to input channel A of the Cortex, and then plug your right aileron servo into servo port A of the Cortex. Just do that for all the channels you wish to stabilize.
Personally, I just installed a Cortex in the Skmaster small Hawk that I just completed. I added a JR G370A for the nose wheel steering. I considered using a Y harness or a Matchbox to match it to the rudder but I also wanted to be able to have a separate gain control for the nose wheel and to be able to disable nose wheel steering while the gear is retracted. Since I already had the JR gyro on hand it just seemed to be the simplest solution.
As for Dual Rates and Expo, yes you can still use them you will probably want to cut the expo in half or possibly eliminate it completely when the Cortex is enabled. On my other plane that I tested the Cortex in, enabling it made the controls feel like there was LOTS of expos. I have my transmitter setup so that enabling the Cortex automatically cuts the expo in half on all controls. I'll fine tune it from there after test flying the new plane later this week.
Also, when doing the setup procedure, make sure your dual rates are at the highest setting that will be needed for this airplane and that nothing binds at this setting as the Cortex uses these to determine it's travel limits when making corrections.
